illini
The Past is Alive
I have a SL-7 that has tonearm drive issues.
The tonearm drive belt has decayed and left rubber deposits on the brass pulleys. What's the safest way to remove this? I have tried IPA, wooden toothpicks, and scotchbrite with little results. I don't want to use too much force and damage the axle or apply a dangerous toxic rubber removal product. Also, should the plastic gears get white lithium grease?
Should the dust cover bearing (rests above the spindle/stabilizer) also receive white lithium grease? The grease is currently black.
And for the tonearm drive bearing rod, I've seen these with and without any lube and I would like some recommendations on that if possible. This one has no lube:
