Hi everyone.
I've spent a few hours these past days trying to get someone's Dual 1229Q to work and at this point I'm completely stumped.
The turntable is in good condition cosmetically, it does not appear to have suffered any abuse. All of the mechanisms are in working order (ie. it'll pick up the arm at the end of an LP if I spin the platter by hand, etc.), the motor runs, the strobe lights up, etc. etc. etc.
But it Just. Won't. Spin.
We've already gone over it several times looking at the mechanism from all angles, we've cleaned everything thoroughly several times, I've even swapped my 1219's idler wheel for his to rule that out, and that wasn't the cause - the 1229Q still doesn't spin up and my 1219 works perfectly with his wheel. So it's not that either.
The speed selector moves freely and appears to operate properly, the spring that holds the idler bracket to the motor pulley does not look stretched or otherwise 'off'; there is no slippage at the motor pulley (I've tried stopping it with two fingers and I can't), the idler and platter spin freely on their own, or at least appear to.
I can even press down on the idler bracket in the direction of the platter and it still won't spin up. We've looked at the service manual. We just don't know what else to do. It doesn't make sense to either of us - all of the intervening parts and mechanisms appear to be working properly.
I've looked at the thing from underneath while it's (not) spinning and have noticed that movement stops at the idler-platter contact point - the motor spins, the idler spins, the platter doesn't. It looks at though it's slipping (it is), but we've cleaned the platter thoroughly and it's still got the known-good (and clean) idler in it. I can push the platter by hand so it's not frozen stuck.
Like I said, completely out of ideas. I was the one who recommended the purchase (...) so if someone could help out a bit I'd truly, TRULY appreciate it.
Thanks in advance and take care,
D
D
. At least now I know how to do it on my 1219. BTW do you use grease or oil on these?
