G-7000 suggestion for output transistors and variable bias resistor
airtime
AK Subscriber
I need replacement transistors for a G-7000.
Which ones should I use?
MJ15025 / 15023
or
MJ21193 / 21193
or
MJ21195 / 21196
They blew out by a failed variable bias resistor VR05. This resistor is rated 220ohms and 2A. What replacement can I use? They come in watt ratings.
Thanks
charles
As far as output transistors, any of the above will work fine. I personally like the 21193/94.
The bias adjust pot is a plane-Jane 220 ohm 1/2W trimpot and a 200 ohm will work fine here. The 2A you are seeing in the manual has nothing to do with current...it is the location of the device on the drawing (vertical '2', horizontal 'A' for one channel, and 'C' for the other).
