Hi there
I'm new among your community and even Know lots of comment have been made about this amplifier I don't seem to find an answer to my problem.
I started to restore my 517 with a recap I've used the same value capacitors just a notch higher voltage (100V instead of 63V) I didn't touch the 4 big filter one (12000uF 63V)
Here Are the symptoms when I power on the protection doesn't come off and I stay with the blinking power light
when I go to separated amp/pre or capacitor coupled the protection does come off (and the red light stop blinking)
even when I link the pre & amp and switch the subsonic filter ON the protection comes off and the relay comutes
At this stage only one chanel is working fine (the right one) the other one has almost no signal only background noise (souffle in french) the defeat filter make a big noise when switched but seem to work
I checked the 2 fuse resistors on the 2 drive boards (R23 R25) and they all seems to be OK (150 ohm)
For info I 've just cleaned and recap the power supply board and the 2 drive board all the rest was left untouched and it was working perfectly before the recap.
I really Hope you can help me with this problem
Thanks
Samy
Thanks
Samy
::tresbon:
