Ohighway
Wannabe Minimalist
Edit 3-19-12. I had the mods change the title of this thread.... which was formerly called "Accidental Involvement / TD-124. It's Ehoove's fault...."
So last Monday Ehoove is over here to lube up my TD-160. After we're finished he mentions he's never seen a TD-124 in person. I grab the one I bought a year ago off the shelf and we start looking it over.
TD-124, series 1 with SME S2 improved arm and Shure V-15 type II cartridge.Grubby and grimy as hell, stylus missing from the Shure. Traveler weight missing from the SME. :sigh: Speed selector stuck in 16 rpm position and plugging it in netted a barely moving platter. We looked, talked, and he left.
Later that evening curiosity got the best of me. I knew it was a BAD idea to try and force the speed selector at the selector lever itself. So I tipped it up and realized that a mechanism was probably just gummed up tight on the shaft. Working it back and forth from underneath, adding a little light oil to seep in finally loosened it up. I could change speeds but... still moving slow. Belt was toast.
Later in the week I received a belt in the mail, cleaned up the pulleys, lubed the speed change mechanism and popped the belt on. OK, good so far but now I notice the idler wheel is cracked. No surprise but...:sigh:
After getting a bit more inspiration by viewing Fast Eddie's thread with pictures I decide that this thing needs a general disassembly, cleaning, rebuild. I will say the platter shaft and bushings are in GREAT shape.
Today I decide to dig deeper. Removed the motor, and disassembled it. The bad news? Broke a nice screwdriver I had getting the motor pulley off. The good news? Motor shaft is flawless and bushings are in great shape.
Soooo..... Soaking the bushings and felts, etc. in an attempt to clean them up. I'm sure the true believers will give me crap but I'm going to re-use the original bushings, etc. A new or rebuilt idler is a must though....
And it's all Ehoove's fault...
I wouldn't be doing this yet if it wasn't for him wanting to see it. It's fun to work on a quality, precision device !
