Posting pics help, please.
Mike Bama
More volume, please!
I have noticed some have posted multiple pics that show up as pics, instead of links for the pics. When ever I post more than one, it *always* shows up as links to each. How do you post multiple pics, and have them show up as such?
Thanks
We cheat. Basically how I do it (as I learned from seeing how others did it) is attach pictures as normal. Then, I right click the link to the picture and copy that link and use the "Insert Image" function with that link. The easy way is to make the post with the pictures and then edit your post. Once you get good at it, you can copy the links directly from the "Manage Attachments" window and do it the first time. Repeat as necessary and there you have it.
- JP
Photo Posting Tutorial
Posting Pics; or how to display multiple attached images in a post.
1. Welcome to your Advanced Reply window. When you want to attach a picture, click the button center bottom named "Manage Attachments."
Clicking the button will launch another, smaller window titled "Manage Attachments." You will not see this unless you tell your pop-up blocker to let it show.
2. Attach a picture as you normally would, by clicking the "Browse" button and navigating to where your image is stored on your hard disk. When selected, click the "Upload" button. You may do this repeatedly for multiple images to a limit of 5 times.
3. The images that you have attached will show at the bottom of the window as "Current Attachments." To show these images in your post when more than one is attached you will right click on the hypertexted name and click "Copy Shortcut."
4. You click "Copy Shortcut" for one image and then navigate to where you have been typing your response. To insert the image, you will then navigate to the "Insert Image" button, which is indicated in this image in the red box. Another small window will pop up asking for the link to your image. To complete this action, simply paste your link (depress CTRL + V simultaneously) and click OK.
For multiple images you will repeat the steps 4 and 5 for each seperate image.
You will know this has worked when you see the below IMG tags for each attached image. To verify, simply click "Preview Post."
Congratulations! You have just learned how to attach multiple images (I hope).
I hope this helps in some way. Images always seem to work better than written instructions alone.
- JP
Perfect !
Great job Charivari.
I have to thank you for taking the time to put this together. I was searching to see how this was done, and ....here it is.
This belongs in a HELP section.
:thmbsp: :thmbsp:
Ken C
Good old post. I am going to try this over the next couple of days and get my pictures there.
thanks,
Vito
