matrix
Hello,
The head-base plate of eralier production models of the RT-909 was not made of pure aluminium. It was just coated with a chromium layer.
Actually there are a lot of decks having cosmetic issuses. The head-plate coating is bubbling and finally flakeing off.
There is no possibilitiy to repair it. The replacement of the head plate is the only way to go, but this means that the heads have to be moved to the new plate.
And here we have the next problem: it is not possible to do that once the heads have wear on their surfaces. Moving the heads from their position will damage with the sharp groove edges any tape played afterward.
To be able to move the heads to the new plate, it is a must to relapp them first.
Sure a good relapping job can be done by JRF but it is costly. Much more there is a lot of work to remove the head assy from the deck and then to mount it back after relapping.
Now I found a very good and cheap solution to repair the old bubbled head plate.
It takes just minutes to do it, no issue with the heads and no opening of the deck.
The solution I found is a custom made fascia of thin aluminium (0.5 mm thick), with adhesive on the rear.
This fascia have only to be sticked like a label over the old head plate.
It is manufactured with high precision and all holes are matching perfectly to the screw holes already present on the original head plate.
All what can be seen afterwards is the border (thickness) of this fascia, it is brighter as the old head-base is.
But in my oppinion it looks really good with this bright border.
Here is a picture showing the old bubbled head plate and the new self adhesive fascia.
It is visible how thin this fascia is.
I'm happy now to be able to repair any bubbled head-plate in minutes, without the huge work of head-assy removal, relapping, etc.
Kind Regards,
Vlad
Kind Regards,
Vlad
