sx 1010 parts
loose ends
Well-Known Member
I was wondering if there is a complete parts list for the sx 1010. I may be getting too old because I searched all the posts and didn't see anything. I say Mark's list for the awr 054 but I have 2 to do and they are both mine so I want to do a complete overhaul.
Roy
Here's a list I received from Mattsd:
Pioneer SX-1010 recap list
Muting Assembly (AWM-039-A)
AWM-039-A: C1: .47uF 50v CEA: 667-ECQ-V1H474JL .47uF 50v
AWM-039-A: C2: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
Equalizer Amp Assembly (AWF-013-0) (Q1 & Q3 and Q2 & Q4 must be gain matched.)
AWF-013-0: C1: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C2: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWF-013-0: C5: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C6: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-013-0: C9: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C10: 100uF 6.3v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C11: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C12: 10uF 10v CEANL: 647-UKL1C100MDDANA 10uF 16v
AWF-013-0: C19: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C20: 100uF 25v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWF-013-0: C21: 220uF 16v CEANL: 647-UKL1C221KPDANA 220uF 16v
Q1: 2SA725: 512-KSA992FBU
Q2: 2SA725: 512-KSA992FBU
Q3: 2SA725: 512-KSA992FBU
Q4: 2SA725: 512-KSA992FBU
Q5: 2SC1313: 512-KSC1845FTA
Q6: 2SC1313: 512-KSC1845FTA
Q7: 2SC1313: 512-KSC1845FTA
Q8: 2SC1313: 512-KSC1845FTA
Control Amp Assembly (AWG-027-0) (Check C49-52, can be 100uF 16v instead of 47uF 16v like the manual states.)
AWG-027-0: C1: .33uF 25v: CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-027-0: C2: .33uF 25v: CSSA: 667-ECQ-V1H334JL .33uF 50v
AWG-027-0: C7: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C8: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C13: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C14: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C15: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C16: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C23: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C24: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C25: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C26: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C29: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C30: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C31: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C32: 4.7uF 35v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWG-027-0: C39: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C40: 4.7uF 25v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-027-0: C41: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C42: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWG-027-0: C45: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C46: 100uF 10v CEA: 647-UPW1E101MED 100uF 25v
AWG-027-0: C47: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C48: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-027-0: C49: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C50: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C51: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
AWG-027-0: C52: 47uF 16v CEA or 100uF 16v CEA: 647-UPW1E470MDD 47uF 25v or 647-UPW1C101MED 100uF 16v
Q3: 2SC1313: 512-KSC1845FTA
Q4: 2SC1313: 512-KSC1845FTA
Power Amp Assembly (AWH-032-0) (Check board number, the D version does not have the 1.5uF cap.) (Q1 and Q2 on both boards must be gain matched.)
AWH-032-0: C1: .68uF 25v CSSA: 667-ECQ-V1H684JL .68uF 50v
AWH-032-0: C2: 1.5uF 25v CSSA: 647-UKL1H1R5MDD1TA 1.5uF 50v
AWH-032-0: C4: 10uF 16v CEA: 647-UPW1E100MDD 10uF 25v
AWH-032-0: C8: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
Q1: 2SA726: 512-KSA992FBU
Q2: 2SA726: 512-KSA992FBU
Q3: 2SA726: 512-KSA992FBU
Q5: 2SC1451: 512-KSC3503DSTU
Q6: 2SC1451: 512-KSC3503DSTU
Protection Assembly (AWM-062-0)
AWM-062-0: C1: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062-0: C2: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062-0: C3: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C4: 330uF 6.3v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062-0: C5: 4.7uF 25v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWM-062-0: C6: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
Q6: 2SC945: 512-KSD1616AGBU
Q7: 2SC1384: 512-KSC2690AYS
1N4004 flyback diode is added between pins 9 (anode) and 10 (cathode)
Power Supply Assembly (AWR-054-0)
AWR-054-0: C8: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C9: 470uF 80v CEA: 647-UPW2A471MHD 470uF 100v
AWR-054-0: C10: 100uF 63v CEA: 647-UPW1J101MPD6 100uF 63v
AWR-054-0: C11: 100uF 63v CEA: 647-UPW1J101MPD6 100uF 63v
AWR-054-0: C12: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWR-054-0: C13: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWR-054-0: C14: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWR-054-0: C18: 1000uF 35v CEA: 647-UPW1H102MHD 1000uF 50v
AWR-054-0: C19: 220uF 16v CEA: 647-UPW1V221MPD6 220uF 35v
AWR-054-0: C20: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
AWR-054-0: C21: 2200uF 10v CEA: 647-UPW1C222MHD 2200uF 16v
R11: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
R12: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
R20: 3.3 Ohm 1/4 watt: 660-MF1/4DCT52R3R30F 3.3 Ohm 1/2 watt
R21: 10 Ohm 1/4 watt: 660-MFS1/2DCT52R10R0 10 Ohm 1/2 watt
Q1: 2SD313: 863-MJE15032G
Q2: 2SC869: 512-KSC2383YBU
Q3: 2SC869: 512-KSC2383YBU
Q4: 2SB507: 863-MJE15033G
Q5: 2SA628A: 512-KSA1013YBU
Q6: 2SA628A: 512-KSA1013YBU
Q7: 2SD313: 863-MJE15032G
Q8: 2SC1384: 512-KSC2690AYS
Main filter caps, 50x90mm (Digi-Key):
565-3331-ND 18000uF 75v screw terminal 50.80mm dia x 79.38mm high
BOM List:
647-UPW1A331MPD | 4
647-UKL1H2R2KDDANA | 6
667-ECQ-V1H474JL | 1
647-UKL1H4R7KDDANA | 4
647-UPW1E101MED | 7
667-ECQ-V1H334JL | 2
667-ECQ-V1H224JL2 | 2
647-UPW1V101MPD | 2
647-UPW1V221MPD6 | 1
647-UPW1J101MPD6 | 2
647-UPW2A471MHD | 2
647-UPW1C222MHD | 2
647-UPW1H102MHD | 1
647-UPW1H470MED | 2
647-UPW1V4R7MDD | 5
647-UPW1E100MDD | 6
667-ECQ-V1H684JL | 2
647-UKL1H1R5MDD1TA | 2
647-UKL1E101KPDANA | 4
647-UKL1C471KPD | 2
647-UKL1C221KPDANA | 1
647-UKL1C100MDDANA | 2
512-KSC1845FTA | 10
512-KSA992FBU | 12
512-KSC3503DSTU | 4
512-KSC2690AYS | 2
512-KSA1013YBU | 2
863-MJE15032G | 2
863-MJE15033G | 1
512-KSC2383YBU | 2
512-KSD1616AGBU | 1
660-MFS1/2DCT52R10R0 | 3
660-MF1/4DCT52R3R30F | 1
