tsd71
RIP Tom Petty
I have a 1250 that I got for $50 in 2008, I started right away repairing it, but put it aside for these years due to some health problems. I pulled it out of the garage last week and have spent the last few days getting it together. The receiver would not power up and would blow fuses and fry the microtemp. I corresponded through these boards with Markthefixer over that time and recapped, replaced transistors, diodes, trim pots, relay, and outputs....It is almost totally new. Last night I finished up the stabilizer board, today I put everything back together. I brought it up on a 75 watt dim bulb and both the soft start and the speaker relay engaged...I was a happy camper..this receiver hasn't powered up since 2000. Now as I went to make adjustments to the trimmers, now on full power, I noticed when I went to set VR1 it read 0.00V, I figured good thats a good DC reading. Then went to adjust VR2 on the power amp and turning the trim resistor does nothing, it reads 0.00MV and does not change at all moving it. This is on both channels.
Any ideas, both relays engage when powered, no smoke anywhere, tuner is getting signal.
Thanks:yes::yes:
Thanks:yes::yes:
