Here are some pictures of my Kenwood KA-7100 re-cap. I used all Nichicon KW audio grade caps throughout, except for where there were orange Elna caps, in which case I used Nichicon KL low-leakage.
Some observations made...
1) If you have trouble setting the offset, try cutting the yellow and blue input wires to the power amp. This separates the pre and power amps, and will show if you have a bad component in the pre-amp causing a DC offset. This might be old news for experienced techs here, but I'm mentioning it to help others.
2) Don't bother replacing the single bi-polar electrolytic with a fancy Nichicon Muse. It is part of the protection circuitry, and isn't really in the signal path. Just a plain old VP series will suffice.
3) Unless you want the absolute best sound while using the subsonic filter, don't bother to change the two tantalum bead capacitors between the toggle switches.
Lee.
Lee.
