canuckaudiog
On a quest for high fidelity
All right AK!
Since I was so successful with the right speaker, it's time to do the left. This time I'm gonna include many more pictures so you can all see what's going on. Might be a good reference for anyone who does the crossover cap replacement on these most excellent loudspeakers.
OK so tools:
Solder iron
Vacuum Solder Sucker (could use bulb or braid too)
Long flathead screwdriver (for prying crossover board off of foam)
Philips Screwdriver (for taking front baffle off)
Pliers (needle nose is best)
Wire brush (for cleaning foam off of crossover board)
Capacitors to replace with (I bought mine from falconacoustics.co.uk - excellent price! no affiliation)
Good light source (don't wanna do this in the dark)
Pants
Your sanity
Process:
OK so first it starts with the speaker itself. Look at how glorious she is.
Don't worry babe, you are only coming apart for a little while!
OK now onto the dissection..
Here is where that flathead comes in handy. You need a long one.
OK good, the crossover is unhinged. Now time to unhook the wires.. take some pictures of what is what of course!
For easy reference, inside the speaker the wires going on the top of the board are bundled together and look to be coming from the speaker terminal, whereas the bottom wires are also all bundled together.
If you are using this thread to help yourself do an IMF TLS 80 II crossover cap replacement, the color of wires go:
Top: Black Red White Blue
Bottom: Black Green Red Orange Yellow Purple White Black
The length of the wires also helps you figure out which one goes where, but a picture is worth a thousand words!!
Next, we take the wires off.
Bottom wires are off, now the top wires..
OK, good to go now. We've got 'er out of there, time for the dirty work.
Use a wire brush to clean off as much foam as you can. You could use rubbing alcohol to get the glue off, I couldn't find my bottle of it around the house so I just wired brushed it off as best I could.
Now onto the whole reason we're here, the capacitors need to be replaced!
OK, halfway there. Now for the rest.
And we're done! I didn't do the green caps because I don't want to replace good parts. They are original to this crossover so they are the best part for the job. That isn't to say you couldn't replace them, I just opted not to.
Now this is where the hard part begins, putting in the crossover board. Rewiring it inside the speaker is not an easy task, I recommend you get an extra pair of hands to help you with it.
Once I'm done this step, I will put more photos up. To be continued..
OK so tools:
Solder iron
Pants
Your sanity
Process:
