I was asked for a fairly detailed 2270 restoration thread. I recently was sent two of them to be serviced. I will post a bunch of pics of the first which is almost complete, then as I do the second any detailed pics anyone may want can be added.
First, condition wise this pair are within 1000 serial numbers of each other, mid 20000s. They both work, but are both not to factory spec. On the scope with an 8 ohm load they are pushing around 42-50 watts maximum out of each channel. Clean waveforms and will not clip even at maximum volume. I am sure the electrolytics are tired and should have some other updates as well.
I will post pics and descriptions as I go along. For this work Panasonic supply filter caps, Nichicon electrolytics PW and KL series, and Panasonic stacked films will be used.
