jackgiff
Well-Known Member
I just purchased a Pioneer SX-1010 from an AK'er (thanks fdejong) and it had what I assumed was a power supply problem. It would only play for a few minutes before it starting going in and out of protection.
When I received the unit, the wood cover and bottom were the first things to come off. There was no obvious damage to the power supply board. I had sort of expected to see it in pieces.
The problem was traced to the protection circuit, and one of the 330 uF caps was the culprit. All of the electrolytics on this board were replaced, except for the .22 uF's, which I didn't have. No .22 uF mylars or foils either. I will pick up some at my son's company, and replace the electrolytics with mylar.
Now the unit plays for hours on my bench, but WOW! The two amplifier heat sinks got amazingly hot. I checked the offset and bias, which were both within spec. But the bias current specified ends up consuming 22.4 watts in biasing the output stages. Seems excessive to me.
The SX-1080, with similar power amp and current sensing technology, uses only 30 milliamps instead of the the 50 milliamps specified for the SX-1010. I set the bias current in the SX-1010 at 30 MA, and can't tell the difference just by listening. But it sure cuts back on the heat from the output heat sinks.
The distortion may be increased by cutting the bias current, but I have no distortion measuring equipment. Maybe one of the Pioneer gurus will pop in here, and give me a lesson on how that is wrong. I am certainly no audio amplifier designer.
The parts for the power supply board re-cap are on order, and the performance of the 1010 is really very impressive.
