Another AK member (DCinDC) and I have been kicking back and forth in a thread over on Vintage Solid State the question of whether coils (including open coils, inductors, and variable inductors) change value and need to be adjusted when performing an alignment.
I maintain that they DO change (the variable ones at least) due to impact/vibration and/or being adjusted by someone else prior to it landing on my bench. I see improvement in low frequency sensitivity quite often when I go through that part of the alignment.
DCinDC says not so and to stick with cleaning the capacitor (which I agree with as a first step when it comes to tuners/receivers that have open frame caps). But, he doesn't see value in checking & adjusting the inductors as needed, where to me that is absolutely a necessity if you want to be sure the tuner is 100% aligned.
Comments?
John
Comments?
John
