A few days ago a customer brought in a pair of SP-3500 speakers with rubbing voice coils in their woofers. Fortunately for him the rubbing was caused by misalignment, rather than his speakers being smoked. Unfortunately, they still needed to be surgically repaired, as there is no reliable way to fix the rub outside of removing and reinstalling the entire cone assembly.
In the process of determining the correct approach to restoring his model W-114, 14" woofers, it became clear that their suspensions were much too stiff for woofers. I checked their free air resonance and found it to be 75Hz!
The W-114 woofer uses a doped cloth, inverted half roll, suspension. While the "goo" that is used to dope the cloth is very similar to what Altec used on their woofers, the Altec dope does not stiffen up. The dope on the W-114s had dried out, thus their being overly stiff. Years of experience, and the knowledge that those suspensions had to go anyway in the process of rebuilding the W-114s to be rub free, prompted me to try to resoften the dope. Using a new (clean) acid brush, I applied a liberal amount of MEK (methyl ethyl ketone) to the cloth roll suspension and exercised the cone in and out while the MEK evaporated. I then retested the free air resonance of the speaker, and found it to have dropped to 42Hz!
I suspect that most any Sansui speakers of that vintage which used a woofer with a doped cloth suspension have lost some of their low frequency performance due to this stiffening. As MEK is almost certainly the solvent that was originally used to thin the dope, I suggest that anyone with old Sansui speakers whose woofers have that suspension investigate the possibility that their woofers have stiffened up. If so, those woofers can be treated as I've described to restore the resiliency of their suspensions.
TG
TG
