Hi Guy -- Stills authored a number of articles for Glass Audio, and while I could pick at some aspects of his designs, I do applaud his KISS approach and how he directed his projects to all levels of diyers.
One comment I would make for your consideration is the OPT. Stills always championed Hammond, likely because of their numerous outlets and quantity regarding availability. And while the particular Hammond he chose for this amplifier has had good reviews, no Hammond OPT can match the performance of Dynaco transformers or their modern day clones. Plus, the Hammond transformers require the goofy feedback selection switch and reconfiguration of the secondary wiring to accommodate all the various output taps, where as you have no such issues with the Dynaco clones.
If you did upgrade to a Dynaclone (MK III) transformer, it would be a perfect match for this amplifier, and provide a significant performance upgrade, but would require a reworking of the feedback/stability networks. I realize that this is beyond your capability at the moment, but did want you to realize that a notable performance improvement is possible with this swap if you have facilities/friends who are capable of making the necessary changes for you.
Other than than, you should enjoy the amplifier very much.
Good luck with your build!
Dave
