Recapping and upgrading a trusty 7100 I got. Most likely going to give it to my daughter who's into vintage stuff. So far just the main board/power supply is done (though I may still put in some new resistors). For the trimmers I used 500 ohm Murata multi-turns. Pulled, cleaned, greased and reinstalled the power Qs and then checked and adjusted the Offset and Bias. Main filter caps are Panasonic TS-HA's bypassed with 1uF film caps underneath. The other caps are also mainly Panasonic FM/FCs except for the LL which is Nichicon UKL.
Before and After Pics
