Jim Creek
Jazz, Wine, Electronics
As some of you know I recently purchased a blue VPI Traveler.
OK, I've run into bad luck with my VPI. I didn't want to post a whine, "oh woe is me" rant and cast a dark cloud on this forum. Instead I've been quietly talking to VPI and troubleshooting my issues. It's under control now so I'm feeling better.
Issue #1: On startup the turntable would not turn unless I gave it a push. It would chirp and buzz but not move. Then the platter started turning backwards! Yikes!
Issue #2: While *carefully* changing carts the one of the bearings on the tonearm detached from the gimble.
Issue #3: After changing the tonearm height the damped cueing malfunctioned. The tone arm would not lift up high enough.
All these issues hit me at once. I needed to suck it up and either return the table or work with VPI and solve them. I decided to fix the problems.
Issue #1: VPI and I came to the same conclusion. It was a failed capacitor. The motor on the Traveler is bolted to the plinth. So VPI offered to ship a new plinth complete with new motor. It's on its way. All I have to do assemble the tonearm and platter when it arrives.
Issue #2: The tonearm is held in place by adjustable set screw/pins. Apparently the vibration of transportation may have loosened one up enough to release the arm from the gimble. It could have been an assembly error as well. Who knows? It was a simple matter of aligning the tonearm back into place, screw down the set screw then back it off by 1/8th turn as instructed by VPI. It works beautifully now. I learned something about the tonearm from that experience.
Issue#3: I discovered that after adjusting the tonearm height the damping mechanism also needs to be adjusted. The damping mechanism is ahigh quality machined piece but needs to be adjusted with tonearm height. It's held in place with a set screw and can be easily adjust up or down or rotated as needed.
This has been a great learning experience for me. Issues #2 & #3 are history. I haven't received the plinth yet. I know VPI is standing behind this table and have no more worries.
This is an 'audiophile' table that requires meticulous adjustment to work properly. Once adjusted the table sings!
In the meantime I can listen to this table if I give it a push. It sounds terrific and I love it. I'll post again when I get the new plinth.
CYA guys later.
CYA guys later.
