KG4 specs
If you are still looking here are the specs for those with KG4 speakers. Found the data out on the net a couple years ago when I bought a pair. Note the 1800 Hz crossover frequency.
The crossover contains a thermoswitch type device (RDE 070) like that you see on the KG 4.2 circuit that moray james posted. I think this is for protection of the k-74-k tweeter, so I would follow moray's advice and not cross it over too low.
Here's the KG4 specs:
FREQUENCY RESPONSE: 38Hz-20kHz±3dB
SENSITIVITY: 94dB @ 1watt/1meter
POWER HANDLING: 100 watts maximum continuous (500 watts peak)
NOMINAL IMPEDANCE: 6 ohms
ENCLOSURE TYPE: Bass reflex via passive radiator
DRIVE COMPONENTS: Two-way system using one 1" (2.54cm) phenolic dome compression driver tweeter with a 90°x40° Exponential horn, two 8" (20.32cm) front-firing, poly ICG cone woofers and one 12" (30.48cm) rear-firing, fiber-composite cone passive radiator
TWEETER: K-74-K 1" (2.54cm) Phenolic dome compression driver
HIGH FREQUENCY: 90°x40° Exponential Horn
HIGH FREQUENCY CROSSOVER: 1800Hz
WOOFER: Two K-8-K 8" (20.32cm) Poly ICG cone active / KD-12 12" (30.48cm) Fiber-composite cone passive
DIMENSIONS: 24.25" (61.6cm) x 15.75" (40cm) x 10.75" (27.3cm)
WEIGHT: 40 lbs. (18.2kg)
ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
FINISHES: Walnut Oil, Oak Oil, Finished Black
YEARS BUILT: 1985 - 1992
Cheers:
