Here are some pictures of my Advent Maestros. Toasted Almond should get a kick out of this, since I bought them from him. Again, I put restoration in the title, but all I did was re-foam the woofers, replace the caps in the crossovers, and do some work on the cabinets. This pair were made in early July 1988, according the the stamp inside the cabinets.
Here are the woofers before refoaming :
Here are the cabinets. The Maestro's had this covering of foam on the baffle, and like the foam on the woofers, it goes all sticky and flaky. I tried using goof-off to remove the residue once all the old foam had been scraped off, but it was taking too long. Instead, I used a rubber wheel mounted in a drill, the kind used to remove vinyl decals and adhesive residue from cars. I bought mine from Eastwood, you can find a link here :
http://www.eastwood.com/vinyl-eraser-and-arbor.html
Here is a closeup of the drivers, including the re-foamed woofers
Here they are, put back together with the foam/adhesive residue removed. I might have to make another wooden trim piece to replace the missing one.
One thing that looks weird is the woofer trim rings don't sit all the way back. It looks like the woofers aren't screwed in all the way, but the frames are touching the cabinets. The original foam would have hidden this. I can either put the foam back, or make some rings from thin MDF or masonite to close this gap up.
So, how do they sound? Preliminary listening reveals a speaker that's pretty good at everything. I was expecting the bass to dominate, given the extra large cabinets and 10" woofer, but it's the treble that I first noticed, very detailed. I tried listening to some Jill Scott, and on particular track (Gettin' in the Way), the backing vocals really jumped out at me, I don't remember hearing them quite as apparent as before. Maybe it's the dome midrange these things have? I will have to get some sealing tape for the drivers, as there is nothing sealing them to the cabinets (bad news for a sealed enclosure design). At one point, I felt the tweeters, and I could feel the plates flexing as the pressure inside the cabinet was pushing on them.
Lee.
Lee.
