radiotvnut
A few weeks ago, I saw this Magnavox console record player at the flea market. When I first saw it, I noticed no indication of it being solid state anywhere on the unit; but, after I got it home, I discovered that it was indeed solid state and has a date of 2/65 on the chassis. The cabinet is in above average cosmetic condition; but, I had to fix one of the leg mounts where it had ripped out of the cabinet bottom.
When I pulled the back, I discovered that someone had robbed the speakers. The only speaker left was one of the original cone front firing tweeters. I had a couple of full range speakers that I salvaged from a cheap '70's Morse console; but, it would be nice to find some Magnavox originals. This originally used two 8" woofers and two 5" cone tweeters.
The changer mechanism works perfectly; but, the needle is broken and it appears that the cartridge output is weak. I got a very loud buzz when touching the phono input terminals of the amp; but, I'm going to recap the amp for good measure. I'm also going to do some cleaning/relubrication on the record changer in order to make sure it continues to work perfectly. From my experience, these '60's Magnavox Micromatic Collaro record changers were among the better ones that were more gentle on records. I've still got some records that were heavily played on such a changer and they sound fine when played on a component style turntable.
I've included a picture of the remaining tweeter. Hopefully, I can find a matching tweeter or possibly someone could recommend something that's currently made that would be a good choice. I've also included a picture of the warranty tag that I found inside the stereo. You're not likely to find this kind of warranty on modern junk.
This must be my week for finding consoles with missing speakers. The other day, I found a '63 Westinghouse that was missing it's speakers.
