sKiZo
Hates received: 92644 43.20°N 85.50°W
The victims - McIntosh XR16s. I've had them for 30+ years, so I'm kinda sorta attached to them.
- Speakers are rated at 89db
- I like prog rock with lots of bass ... think Porcupine Tree and Genesis. I'll normally listen at moderate (to me @95db peak) listening levels, but it'd be nice to know whatever I get can handle the big boomers ...
- Smallish listening room. Think oversize closet at 600 square feet.
<EDIT> < < ooPs ... That's 600 CUBIC feet ... > > >
Suggestions that won't break the bank? I was just looking at the Yaqin MC10T which seems to jump out of the pack for entry level toobers.
Purty lil thang, ain't it? 52 watts per channel at 8ohm and you don't need a pre, although that would certainly give more flexibility. Only complaints I found were that the original Chinese tubes are borderline average, but ... you can upgrade a bunch rather cheaply with something like the JJ/Tesla KT77 and a couple NOS 6AQ8. Simple plug 'n play tube swap to make the amp sing, and still under $700.
My concern is that 52wpc seems a bit high for paired EL34s ... and I hear tell Chinese amps tend to be overrated. The old Dynaco ST70 uses the same tubes and will do 35w with 70w peaks, but they use different drivers and obviously old school tech to do it. Which brings me back to the original question of how many watts I really need.
Thoughts? Suggestions? Links to threads where this question has already been answered a hundred times? <G>
