Reaching new depths with my new JL Fathom F113
CarnahanBB
Seeking accurate, musical, explosive and dynamic bass I recently dumped my dual Polk PSW-505s and began the search for a subwoofer that could just as easily reproduce LFE movie effects as it could the cannon blast from the 1812 Overture or plucks on the bass. That search lead me to the JL Audio F113.
I was also seriously considering the REL G1/G2, the SVR PB13 Ultra and the Velodyne DD15 but in the end the build quality, reviews and size convinced me that the JL was the best choice.
Yes, it is expensive. Yes, it is heavy. But it takes the term 'built like a tank' to a completely new level. Fortunately for me, it also takes bass to a whole new level. I haven't finished dialing it in yet but thus far 'impressive' doesn't even begin to describe what this sub can do. I basically plugged it in set my XO point at 80hz and enjoyed. Tonight the tweaking phase begins. Fortunately, I've only got so much room flexibility and the manual is really detailed in terms of placement. The JL also has Automatic Room Optimization which should prove to be very helpful. More to come. I just had to share!
That's gonna kick some ass! Very nice.
Thanks! I can't wait to get home from work tonight to do some more tweaking and dialing in.
'Never heard a bad word about JL products.
I'm sure the trend will continue!
That's a big part of what put me over the top. JL has an awesome reputation and I love that their products are made in the USA. Their website has tons of great info. I just felt really positive about the company itself and that has become more and more important for me.
I still run my JL subs in my truck I bought in the mid 90's. That's three vehicles down and on the forth, subs never have given one problem.
I ran nothing but JL Audio cars subs myself for years starting from back about 1992 or so. I had a 12W1, 10W1's, 10W3's and 10WO's over the course of years. Never had one die.
You know, I didn't even realize JL did anything for home audio until recently. From what I've read their home subs have the same reputation as the rest of the company. There are some excellent galleries of their US factory. The link is below.
http://www.jlaudio.ca/galleries/JL+Audio’s+U.S.+Factory/718450
JL came out with that home sub when the W7 was hot on the streets, man the JL fanboys went nuts over it. I blew it off because the fanbois drove me crazy. It really is a wonderful piece of equipment.
That's a serious looking sub. Foam surrounds?
cubdog
Yup, it's JL's patented "Over Roll" surround. According to the literature it's supposed to allow for 4'' of woofer excursion (not that I'd want to see that on my sub). It really is something to behold I have to admit. It's 130 pounds unpacked and the driver is 70 pounds alone. I only wish it had spikes.
You'll really appreciate and enjoy it. It takes a while to find the right location and dial in but the calibration works well. I dialed mine (F112) in for my 2 channel audio and then used the AVR/Audssey when the HT is connected in.
Any reason you chose the F113 over the F112? Most feel the F112 is better for music because it has a higher max freq. (though I don't use mine that high). But the F113 is real monster!
I only had a few (realistic) positions from which to experiment. I went with inside, front, left corner of my listen area with the sub pulled away from the wall as much as possible. I was running it un-equalized the first night and then last night I ran the ARO which was shockingly effective. The before and after difference was night and day. I'm glad I used my brain and chose a sub with automatic calibration. The manual was very helpful in terms of determining optimal positions.
In terms of the F112 versus the F113 I have to say that low end extension was a primary concern for me. I use my set-up for movies, music, television and occasional gaming. If I was doing a dedicated music only system I likely would have chosen a REL G1 or even dual F112s but frankly I wanted the best of both worlds with the least amount of compromise (not the least of which was footprint) and as long as the F113 can play cleanly to 80hz (which it easily does) that's all I require. The F112 can pay up to nearly 120hz but those are frequencies I don't want or need my sub to reproduce. But like you said, given the frequency response of the F112 I wouldn't be surprised if it would make the better 2 channel subwoofer but in my application the trade-offs would have been marginal. That being said, I doubt this will be my last JL sub. I can see why people like them so much. All the better that it's not enormous like the SVS I was considering.
Yeah, those JL subs are real monsters, and their surround design is rather ingenuous. Is that an aluminum enclosure or something?
Nope, it's actually just 1'' MDF all around with quite a bit of internal bracing as well. Just enough to leave room for the driver.
........ I was running it un-equalized the first night and then last night I ran the ARO which was shockingly effective. The before and after difference was night and day. I'm glad I used my brain and chose a sub with automatic calibration. The manual was very helpful in terms of determining optimal positions....
If you want even more improvement get a DSpeaker Anti-Mode 8033. While the JL is a single correction system and works well, the 8033 will give you from 24 to 36 corrections depending on the model, and the improvement over the single is significant IMO. I thought I had great bass until the 8033 was put into play, then I knew great bass was obtainable.
http://www.dspeaker.com/en/products/anti-mode-8033.shtml
