$3.00 'As-Is' Behringer A500 = Simple Fix
Frank Sol
Lunatic Member
Thrift Store looking while I was out for lunch... Behringer A500 had a $5 sticker with "Powers up" :scratch2:
Ok... I could tell it took a big fall at least once because the power button , left output dial were marred , scuffed up and a heat fin on the left was slightly dented
I plugged it into an AC outlet with fear :D -- came on for 1/2 sec then went into protection. Ok , I offered 3 bucks and he took it after he got approval
Got it home... Long story short : the power button was busted-up badly on the inside. I cut it out and hot wired it :thmbsp:
Works great :banana:
I may leave the AC hot wired fix and remove the two output dials from the circuitry. I've read they are cheap and faulty.
Thanks... after a good 30 minutes of on time I checked the DC offset
Ch1/Left = 22.5mV
Ch2/Right = 15.9mV
Not bad
:thmbsp:
Took the the cheap & usually poor performing output Pots out of the circuitry and made the 'hot wire' permanent today...
See link in Post #4
:thmbsp:
What was causing the "protection" fault?
Not the broken power switch, maybe the cheap pots?
Just curious.
Mark T.
Mark , the busted power switch was making a completed connection (power on) no matter what... but I believe was grounding out
BTW - Hold on to your hat :D
After removing the pots and making those 20K plugs running output at 100% the DC offset are incredibly low
Ch1/Left = 2.4mV
Ch2/Right = 1.9mV
:scratch2:
I'm rechecking in about 5 minutes to double check
Project Finished
I did not disconnect the light show on the front panel -- Seems to have no affect on SQ and I sorta like it
I spray painted the power button & output dials Black and super-glued them back on the face , of course they are now dummies. I did not want to fabricate a front panel like some people have...
Going to put her in the main system and hear her through balanced XLR inputs. From what I understand the Behringer A500 is a true dual mono design. I can attest to her exceptional SQ after removing the output pots
:thmbsp:
Ch1/Left = 2.4mV
Ch2/Right = 1.9mV
Rechecked today
Ch1/Left = 2.5mV
Ch2/Right = 2.1mV
