There are several inherent virtues of the dual concentric design. The most obvious being the true point source emanation of sound waves which ensures a phase coherency not attainable by other means.
In conventional multi driver systems, the sound is emanating from different physical planes and positions, making off axis response rather variable. This is complicated by the cossover distributing different parts of the same sound to different physical drivers, which cannot help but to destroy the cohesiveness of the wavefront received at the listening position.
Imagine for example the sound of a viola playing a single musical line, reproduced via a typical two driver loudspeaker system. Part of the sound, including many of the fundamental frequencies, will be handled by the bass/mid driver and part of the sound will be handled by the tweeter.
The problem is, even the lower frequency fundamentals will have harmonics way above the range of the bass/mid driver, which are passed to the tweeter. You therefore have spectral elements of the same note being reproduced by two very different drivers and reaching your ears at different points in time due to the different position of the drivers. This destroys absolute phase coherency and produces different effects at different axial positions.
With a true point source design there are little or no time and phase differences between harmonics either side of the crossover region.
Furthermore, there tends to be a more accurate balance between the fundamentals and harmonics, not only on axis, but even off axis, where many do a great deal of their listening. With the Tannoy dual concentric drivers there is a tight physical integration of the high and low frequency drivers, leading to a coherent and linear phase response. This in turn means that a simpler crossover can be used, providing even greater sonic benefits.
It has long been understood that complex crossovers which attempt to provide phase alignment and other elements of control, invariably have negative effects upon sound transparency.
