sonavor
As an amateur to FM tuner testing, I have some questions about setting up some basic tests. Right now I just want to be able to apply a test signal and verify voltage levels in the tuner (per a service manual) are where they need to be.
I have a Panasonic VP-8193A FM signal generator that has been calibrated. I also have a Tektronix 475, 200MHz oscilloscope.
The first question I have is about the signal generator output level. It is defined as dBuV EMF. In looking that up I found this web site that shows formulas and has a conversion calculator for the various units such as dBuV EMF.
My VP-8193A test results (from the calibration check I had done) show that it is pretty much right on the money with its frequency and dBuV EMF output levels. But what if I want to check the levels with my own scope? So I decided to try and that is where I am out of my knowledge level and would appreciate some help.
The question then, is should I be able to connect a BNC to BNC cable from the VP-8193A signal generator to the oscilloscope and measure the voltage level correctly? The VP-8193A output is listed as 50 ohms. The scope input is listed as 1M ohm. When I try that, I see the sine wave on the scope has the expected frequency but I am not getting the peak voltage levels per the RF Unit Converter for the amplitude setting on my generator.
The FM tuner inputs for are for 75 ohm coax cable. Does that require a 50 to 75 ohm matching pad?
A second question is - I have seen tuner service manuals that say to input a signal at some frequency and a level of 1uV EMF. So I am trying to relate the VP-8193A dbuV EMF output value to a test input requirement of uV EMF units. The conversion chart I gave the link to appears to supply that but I am wondering how I can tell my test setup is actually correct?
