Restoring my Wharfedale E50 speakers
Teaboy
I bought a pair of speakers from eBay recently, and when I picked them up I realised one of the speakers looked a bit weird. The seller told me his daughter decided to try to clean it with a baby wipe. This meant the dustcap was a bit dented and there are some watermarks on it.
I bought them anyway, thinking I would return them if they were not working, and they sounded good when I got home. But a few weeks later I noticed the cleaned speaker sounded a bit weak. The bass sounded a bit distorted and without much power. I checked the speaker and saw the rubber seal on one of the drivers has come loose:
I unscrewed the speaker and realised that 90% of the circumference of the rubber part was basically falling off. A bit of Googling and I found that this is a common problem.
I tried to tried to clean it up by removing the loose bits and glued it with some PVA glue, then put some books on the speaker to hold it down for about an hour. The glue seemed to have dried so I screwed the speaker back in.
This morning I tried to play something and the speaker sounds even worse. I checked the speaker and the glue has basically done nothing, so I need to start again.
There is literally no power in the speaker, just a muffled distortion. Weirdly, I noticed that the speaker sounds powerful again if I put my finger on the rubber seal and apply a tiny amount of pressure.
Any suggestions for what to do next? And how to get the dustcap back into shape?
Don't play it. That's the woofer-surround. Part of the speaker's suspension. It can be fixed, but don't play them until you do. You can fry the voice-coil (Basically, you want to think of it like trying to drive a car with no tires or shock absorbers... You might make it a few feet, but odds are, when you hit that first big bump, something bad's gonna' happen).
The E50's and the rest of the E** series get high marks from the people I know who own them. They apparently work best with a tube amp/tube receiver (or a solid-state amp or receiver with a tube-like sound).
Thanks for letting me know. Luckily I had the volume very low so hopefully I didn't do any damage.
Now, how do I fix it?
I believe there's a way to re-glue it/re-attach it properly, but I'll leave that to the guys who've done that before. Someone should be chiming in about it soon enough (I'm not repair-savvy, just listening-savvy ;) ).
The E** series is under the radar, but supposed to be great. That was their TOTL series in the late '70's (VERY-different from their classic W** series, but still very-good... Just different).
I took the speaker out again and had another look. I realised that there was another paper part that had come unglued - at the base of the speaker. I asked my wife to reglue it with one of her artist brushes, since she is more delicate than I am.
It's currently drying, fingers crossed!
Yeah, I'm not sure what type of glue you're supposed to use, but if it holds, I don't foresee any problems.
So, how do they sound? Like I said, they're very-efficient and designed to work well with tube/tube-like power. I came real close to buying the entire E** series in one shot a while back, but scheduling was an issue (Plus, I already have 3 pairs of Wharfies as it is and not a lot of space to store them, so adding 4 more pairs would have been tough).
If you like those, then you'd really-like the E70's and E90's (The E90's were over $2000 a pair, street price, from what I understand... That series was not cheap).
Got my W90's playing at the moment while I wait for a car battery to charge (Trying to resurrect a second vehicle that's been sitting a while... Also waiting for some yellowjackets to calm down... I had to remove a nest they had built in the driver's-side doorjam, and when I did, they just got PISSED, and one of them followed me back to the car... I think he's got a personal vendetta sworn against me... The first time I tried going back out, he went right for me and tried to take me out).
