OK, here's my bright idea.
Last year I purchased a broken Audio Research D350B power amplifier from a fellow AK'er - it was too cool to turn down.
http://www.audiokarma.org/forums/showthread.php?t=457511
After lots of research and tinkering I came to the conclusion that there was (at least) one unobtanium part that needed replacement. I actually found a source (a former AR employee) for one at the time but couldn't justify the $150 for the part just to find out that it wasn't the problem.
To add to that, I asked - "well what does AR do when these need repair", to which the reply was - "we tell them to buy something new, these weren't very good in the first place". They're big into tubes now - don't you know.
So, after ignoring this project for a year it's time to see what I can make of this.
I'm thinking - what would be involved in reengineering this into a modern SS power amp?
The old amp will contribute the power supply, enclosure, heat sinks, cooling fans, output and line voltage power meters to the new creation.
The power supply consists of 2 separate +50/-50 (with 120,000uf each) and a single +75/-75 (with 7,600uf) supplies.
What kind of advice can be offered as I bumble down this dark path?
