Pioneer sx-1080 channel issue
Pharssa
AK Subscriber
Hi
I have a Pioneer SX-1080 receiver and it has 3 issues.
1. No sound in left speaker in the Phono 2 input but, both speakers/channels work fine on Phono 1 input.
2. Similarly, no sound in right speaker when using FM but both channels work when using AM. Flipping the Stereo to Mono button brings sound in both speakers.
3. No Phono light when using either of the Phono inputs but rest of the lights work fine.
Both channels also work fine when using AUX input. I haven't tested the tape inputs.
What could be wrong and is it easy to fix? Are all the parts available?
Thanks,
deoxit the switches may clear some of it up .
Thanks for the suggestion, I will try that. I played with the switches and Phono 2 issue seems to be the dirty switch as pressing it further beyond the locking brings the sound in the missing channel. FM issue is slightly different. The sound in the missing channel comes for a second and then cuts off when the FM input selector button is pressed; pressing it further beyond locking like the Phono 2 button doesn't help. Could this be a different issue or still most likely a dirty switch?
Thanks,
Most likely a dirty switch. You are going to most likely do some dis-assembly to really clean them.
I looked at the service manual. By dis-assembly, you meant removing the top, knobs and the face plate so that DeoxIt could be applied to the switches from the front or is it more than that?
Pardon my basic questions; this is new to me. Also, should I use DeoxIt D5 (5% solution) or D100 (100% solution) followed by Faderlube - any suggestions on the concentration of the Faberlube solution? I also read that we should let the switches dry for a day after Deoxit. Should there be a day's gap between Deoxit and Faberlube or apply the deoxit then faberlube and then let the switches dry for a day?
Thanks,
Yes, you'll have to pull the face off, and set the receiver up on its back. The buttons can be sprayed from the front. If you look at where the spring is on the buttons, on the bottom right of the switch ass. there is a place you can work the straw in and spray inside. Work the switches for about 30 seconds.
Good idea to go ahead and do the toggle switches also. You can shoot them from the front as well. Spray in the slot at the bottom.
Trying to clean the switches now. Took the top off and all the knobs except the volume - I removed the set screw, still it is not coming out. Any suggestions? Also, do I need to remove the bottom plate for front panel to come out?
Thanks,
Update: volume knob cam out and so is the front panel. Now the deoxit part.
Thanks,
I applied Deoxit Faderlube F5 and worked the switches for 30-40 seconds. Deoxit resolved the Phono 2 issue but not the FM. Still no sound in the right channel in FM mode. Pressing the 'Multipath' button brings the sound in both channels but very low and highly distorted sound.
Any other DIY suggestion or is it time to take it to a repair shop?
Thanks,
Do you have an antenna hooked up?
Yes, but for now, a single wire one attached to the 75 ohm connector. When I tune into a local FM station, receiver picks up the station fine and left channel has full and un-distorted sound but no sound in the right channel.
Thanks,
Does the STEREO indicator lamp illuminate in FM mode when tuned to a strong station? How does the signal strength meter function?
The stereo indicator lights up and signal meter shows very good strength - 3.75 on the scale of 5. I also hear some crackling in the right channel once in a while when moving the tuning knob but no sound when the station is tuned in.
Thanks,
At this point, everything is suspect. However, since the PA1001 decoder seems to "think" there are two channels in stereo (illuminating the STEREO lamp) we might presume for now that the FM front end is intact, and signal is being lost somewhere after that.
Let's try to establish a few more details of operation to help pinpoint the issue(s):
  1. Does the receiver produce sound in both channels in AM radio mode?
  2. Try turning the FM MUTE off to see if there is any inter-station noise in the R channel. You may need to use the balance control to attenuate the L channel signal so you can hear more clearly.
  3. If you remove the lock screw from the slide switch cover on the rear and clean/exercise the FM de-emphasis switch, does it affect anything?
  4. Has the FM Multipath switch been cleaned/exercised?
1. Yes, the receiver produce sound in both channels in AM radio mode.
2. Yes, on FM Mute Off (not pressed in) I hear some inter station noise/crackling in the R channel.
3. Which ones are the slide switch cover and the FM de-emphasis switch on the rear? Can you please point it in the service manual? I looked at the Connection Diagram on page 7 but could not figure it out.
4. Yes, yesterday I sprayed DeOxit Faderlube F5 and worked all the switches including FM Multipath.
Thanks,
<<Update>> 3. if you were referring to the 25uS switch on the front, between FM Multipath and FM Muting switches, pressing it in improves the high frequencies in the sound but no other change. I have kept it off so far.
Thanks once again,
Yes, I had presumed the de-emphasis switch was on the rear like the older series, which included a protective shield to prevent unintentional movement of the switch, instead of the Dolby/25µS bypass switch on the "new" series. So long as the switch is clean it should not affect signal in the FM path.
When tuning an FM stereo broadcast, does the signal strength meter display maximum signal when the tuning meter is dead-center. or does the strength meter show a better signal when the tuning meter is off-center?
For a given station, the signal strength is maximum when tuning meter is dead-center. Also, the stereo indicator is solid ON when the tuning is dead-center. As tuning goes out, the signal strength starts to go down and the stereo indicator lamp starts to fluctuate (come and go).
Thanks,
That may (temporarily) resolve the question of alignment being way out.
Short of a signal tracer, or a generator and 'scope, further diagnosis might get a little dicey. If you have a second unit at your disposal, or can use the Pre-Out/Main In jacks on your 1080, it is possible to construct a rudimentary signal tracer following instructions posted by markthefixer some time ago:
http://www.audiokarma.org/forums/showthread.php?p=3605018#post3605018
With that equipment it will be possible to determine if the RF section is functioning and find where the signal is being lost.
I don't have a second unit, but I can follow instructions to use Pre-out / Main In jacks. I will look at the other thread to see if I can understand it and would feel comfortable trying it.
Watthour, thanks for you help so far. Really appreciate it.
It's not just me. Everyone pitches in around here, and YOU are doing all the hard work.
Mark's instructions involve using a spare (or borrowed) interconnect cable with a small ceramic cap attached to one end. Mark shows the cap lead wrapped around the RCA plug center pole, but a test jumper lead with alligator clips on either end makes it just a bit easier to handle. The free end of the cable connected to the TAPE PLAY input so that FM can be selected while the TAPE MON is on. This allows the main amp to amplify the probed signal.
Tracing the circuits will be as easy as touching the free lead of the capacitor to a few terminals on the unit. The first place I'd look would be Pins 19 and 21 on the tuner board. These are the L and R channels of the FM decoder output, respectively. Those two pins feed the function switches on the switch assembly via Pins 14 and 18. If the signal is about equal on each of those two pins that should prove the FM tuner section is intact.
