cptnCanada
So, in addition to my other thread in the Speaker forum on my Open Baffle Epiphany, I thought I would create one showing the build process of my open baffle speakers from start to finish.
My goal is to have a flat response across the audio spectrum using the open baffle concept. I have chosen Foster (fostex) FE103 alnico for the full range drivers and Eminence Alpha 15A for the low bass duties. There are a lot of projects online that utilize this driver arrangement with the newer Fe103, including the now famous Martin King version which I would imagine sounds terrific.
I've never been a fan of passive x-overs, mainly due to the fact that once in circuit, I always feel something gets lost to the overall transparency of the speaker. Also, having designed them for other speakers is the past, at least for me, they are hard to get right the first time and require a lot of tweaking. This usually ends up with a lot of spare parts and lots of $$ wasted.
This brings me to my x-over of choice - Active. More specifically, the miniDSP. I have not used one yet, but I really like the idea of a programmable xover that can be endlessly tweaked with a few clicks of a mouse. The idea of being able to tweak the x-over if I move speaker positions or move to different rooms is really a benefit. Also, with passive x-overs, you need to create a circuit to to specific jobs, eg. low pass, high pass, notch, etc. With the miniDSP, since it is digital there are no limits to what you can do to the slope - what corrections you want. No need to follow math or electronic formulas. Simply Measure and adjust!
I am planning on going with a flat panel open baffle, probably not much wider than the 15" woofer. I debated trying a "C" of "H" frame for increased low end response, but I should be able to boost this to flat no problem with the miniDSP. X-over point from the 15" woofer to the 4" full range will be determined with measurements once the baffles are built.
Cost break-down:
2x Eminence Alpha 15A $129
2x Foster FE103a $6 (goodwill)
2x Phase plugs for FE103 $18
1x MiniDSP 2in-4out $80
Wood for baffles $20
Total cost for project: $253
I also purchased the UMIK-1 microphone to go with the miniDSP so I can get accurate in room measurements. I haven't included it in the cost as you could do without it. We shall see how useful it is when the project starts coming together.
Another point is this will be a bi-amp speaker. The ultimate goal having a SET tube amp running the Fe103's and SS for bass duties.
Cost break-down:
I was planning something similar a while back, but went with coaxial drivers instead.
