Hi Folks -
I added a relay to my KR-6600 to prolong the life of the power switch and would like to do the same to my KR-6060 - which is the same receiver- except that it has the 120/240 voltage selector switch on the rear panel as well as an additional fuse on the power supply "B" board. http://www.audiokarma.org/forums/showthread.php?t=508615
My thought is to wire the relay circuit to the 120V side of the selector switch (after the main fuse) and call it good. This should effectively disable the 240v side of the voltage selector switch in my thinking, which is fine with me, but it's a bit confusing.
Thoughts/ideas appreciated!!
