thes
Hi there
just found a technics su 8088k amplifier on ebay but the power indicator lamp (wich is a wire incandescent lamp) doesn't light up anymore.
The service manual of this unit states that the power indicator lamp replacement part should be a 7.5V 75mA wire lamp (doesn't indicate the size (3mm or bigger?).
The problem is that i can't find an identical lamp i've only found lamps wich are 5V 60mA 3mm.
Would a 5V 60mA 3mm wire lamp work on this amp? Would it be more stressful for the circuit board?
Please help
Please help
