The unit is a TruSonik 10 liter modle.
https://www.youtube.com/watch?v=7l3ZFCUOd1Q
It came in a record cleaning setup. "Ultra Sonic Record Cleaner V8"
http://www.ultrasonicrecords.com/
The problem is that the agitation stoped working but everything else does, so it's not the main fuse. It seemed like it was starting to slowly go out until one day when I was preheating the tank. When the sonic motors are not on the fan is off but you can set the heater on which can transfer heat so I don't get that. Considering the main board has so many heat sinks for protection.
I called Ultra Sonic Record Cleaner and they are trying to pass the buck but asked me to try and adjust this little blue part right next to the agitation speed control, "nothing from this Adjustment"
Video Here
http://s1171.photobucket.com/user/427fairlane/media/AdjustingPowerOutput_zpsefc7f6d9.mp4.html
Now I have the main board out of the unit can anyone guess what's wrong? I don't have test equipment other than a Multi Volt Meeter. I can find hardly any info on this unit let alone schematic.
The speed control switch has continuity that I can tell if i'm doing it right.
Thanks
Video Here
Thanks
