Here's a pic of the finished deal...I had meant to snap a pic of the 'before', but sometimes I jump into the work and forget that some documentation would be nice.
The stock caps are 15,000µf 100V caps with wire-wrap terminals, and a bizarre ground bus that connects the common terminals. Of course, the stock metal bus piece is useless with the new 22,000µf 100V Nippon Chemi-Con screw terminal caps, so I used a piece of 10ga solid wire bent around a 52mm cap that was laying around for a nice pretty bend, and then used a piece of 14ga solid to wrap around the center of the bend a couple of loops (try it with 14ga wire, not as easy as you might think), and soldered it in place after adding a loop terminal to the end.
All the terminations are soldered, and the end result is (to me at least) as pretty as it is functional.
Just wish I had taken a 'before' pic... :sigh:
