TheBoyGrouch
I thought it might be handy to have a thread for information about these brilliant speakers. I bought my set in 1977 from a HiFi shop in downtown Rome for a million Lire (or thereabouts) and have owned them ever since. They were the go to speakers for the parties we had in those days and spent many a happy hour banging out tunes powered by an amp set to 11.
Owners Manual:
Usual problems with these speakers:
After about 25 years the rubber speaker surround and/or the spider may have come away from the basket on the bass unit. This is due to oxidation of the surface of the basket over the decades causing the glue to detach. Its a simple enough problem to fix, some UHU glue will do the job. If the spider separates from the basket you can temporarily secure it using clothes pegs to make sure it is centered before regluing a bit at a time - the speaker cone should move up and down freely without making any noise.
Replacing the capacitors:
On my 1977 crossover board the capacitors were:
"Tropical fish" 2.2uF 250V (the square red cap with green and white stripes)
An Elcap 4.7 uf 50V NP
An Elcap 16uf 50V NP
An Elcap 50uF 50V NP
I replaced them with:
JB JFX series 3% tolerance Polypropylene film capacitors from audiocap.co.uk based in the UK.
2.2uF 250v
4.7uF 250v
2x8uF 250v in parallel (JB make a 16uF but audiocap didn't stock it).
50uF 250v.
For a total of £45.20 delivered.
http://www.audiocap.co.uk/jfx-audio-film-250v-116-c.asp
A fairly simple process, I changed the caps on one speaker at a time so that I could compare and there was a definite improvement, no doubt. The 37 year old caps were definitely past their best...although some tracks would sound brilliant (usually uncomplicated music with few instruments) most sounded not only muddy and mushy in the mid range but also as if they had been mixed poorly with quiet vocals and lastly as soon as the volume was turned up high the music seemed to lose coherence.
Now they are back to their old glory, I was nervous that they might sound a little sharp with the change to Polypropylene capacitors but no, they sound amazing.
Owners Manual:
2.2uF 250v
4.7uF 250v
50uF 250v.
