Leesonic NAD 3020 Restoration Review!
dryce
I recently sent my NAD 3020 off to Leesonic for a complete restoration. I had been having some minor issues with it. There were times while playing where it would get brief moments of static. I had tried cleaning the controls a few times and the static still persisted. It still had all original internal components, so I figured that was a great excuse to send it out for a fix up. I've read Lee's threads here about his work with these and knew he was just the guy to tackle the project. He has done very fine work on these and I'm certain he could build these things in his sleep by now.
I actually purchased this 3020 off the bay after hearing an unrestored unit with a set of Mission 731 Pro bookshelf speakers and a Marantz 67SE. I thought it had a great warmth and detail to it. I really wasn't expecting the restoration to improve on the qualities that I already enjoyed about the NAD, but I feel quite confident that it has. When I talked to Lee about taking on my unit he had a very organized plan about how to tackle the project. He was very honest about what he felt was needed and what would probably be overkill for the project. I sent it out to him shortly after that conversation and he began working on the 3020.
The project took considerably less time to complete than I imagined. I received an email outlining what he had done with photographs detailing all the work in no time at all. Lee sent a very detailed description of what I was looking at also which was definitely most appreciated. Here is his outline of the project:
Pics 1-5 show how it looked inside when I first opened it.
Pic 6 shows it with 99% of the new caps installed, and the heatsink removed.
Pic 7 shows the heatsink and output transistors with very little thermal grease left.
Pic 8 shows the internal view with all the new caps installed, and the heatsink refitted. See that white stuff around the four output transistors in the center? That's new heat transfer grease.
Pic 9 shows the underside of the board, see how clean it is after defluxing? The four black caps are the Nichicon KLs I moved from the other side of the board to create space for the WIMA films. The two brown-red caps are bypassing the main power supply caps.
Pics 10-13 show me seting the bias and offset voltage. 30mV for the bias, and 0.5mV for the offset seem pretty good. Of course, these values go up and down with heat, but I left it sitting for about 20 minutes and adjusted them every 5 mins.
Pic 14 shows the power supply board. New diodes (circled in yellow), new resistors (green), and new power transistors with heatsinks (red). All the caps are Nichicon PWs (105C temperature rating).
Pic 15 shows the WIMA films (circled in green) in the phono preamp and the beginning of the line driver stage.
Pic 16 shows the WIMA and CD films in the tone control and line driver stage (circled in green), higher value main caps and new rectifier for the power amp stage (red), and new power switch and spark surpressor (blue).
Pic 17 shows new Bournes trimmers (green) and CD caps for the power amp input (blue).
Pic 18 shows the addtional heatsink fitted to the original.
Photos are here:
http://s160.photobucket.com/user/Silverbullet763/slideshow/Nad 3020
As you can see, he did an excellent job. Hopefully, he will chime in here at some point. I had him replace the stock leds with new blue and it really looks great that way. Listening to the restored unit surprised me a great deal. The bass response was greatly improved and sounds that would have been stuck in the background before, are extremely clear and crisp. I was listening to one track in particular that had a very bassy sound to it.
I noticed the woofers on my Klipsch RB-5s moving slightly. I honestly haven't noticed that with any other amp that has been in rotation. Everything from guitar and violin strings to drums and piano sound incredible. My musical tastes run the gamut. I've played Eric Clapton Unplugged, Alison Krauss Live With Union Station, R & B stuff, Rock. The strings really shine and you never feel as though something is off or overblown.
The biggest surprise for me had to be the phono stage in the NAD. I listened to it prior to the restore and it left me feeling a little unsure. The sparkle that the rest of the amp had seemed missing. Thankfully, it sounds great post-restoration. Lots of detail there.
Lee was even kind enough to send CDs back with the amp to test out. All in all I've had a great experience with Lee's restoration work and the amp. The 3020 is now my daily driver and I don't see it ever going anywhere. Just thought I'd share with fellow Akers. It's definitely worth hearing a restored 3020. They really are something special.
Very nice work indeed, and having followed Lee's example(s) with similar NAD's this side of the pond, I can completely confirm it is well worth the effort - they really do come back to life !
Yes they do! It is really an amazing amp.
Leesonic really does amazing work. I bought the 1020 he turned into a 3020, detailed in his thread here.
Congrats on a wonderful 3020 restored by a true NAD artisan!
Sorry for the delay. I thank you for your kind review, the check is in the mail. :naughty:
Seriously though, I work on all kinds of equipment, but these little NAD amps keep finding their way to me. I'll be the first to admit, they aren't without their problems. They look very austere with the grey faceplate, and it's only made of painted plastic. Somehow, this makes them even more vulnerable to scratches and dents. The rear RCA jacks are fragile, and that horizontal surface is a magnet for dust. They only have one tape input, and no speaker switching. And they are only 20w per channel*.
But what they DO do, and what people have been finding out ever since they were launched, is make MUSIC! Before the 3020 came along, NAD were making clones of other amps, with big power meters, lots of buttons, etc. The 3020 came along and changed all that. Simplicity and good design were the key. It uses 15amp output transistors, nothing fancy or high speed, just a 2N3055/MJ2955 combo that you used to be able to buy in Radio Shack in those blister packs hanging on the racks. The power supply was designed with split secondary windings on the transformer, meaning the power amp would never cause a drain on the preamp. Discrete transistor design was used throughout, no op-amps here.
* And the 20w per channel? There's something very special about those 20w. Maybe it's the peak power that these things put out? Or perhaps the fact that low impedance loads don't pose a problem for it. NAD used to do a trick at HiFi shows, they would connect four pairs of speakers to these little amps, and they would drive them without any problems. HiFi magazines back in the day recreated the same stunt, and measured quite a large peak current output.
The fact that NAD are still in business, while some of the other great brands have either gone, exist in name only, or have given up on the HiFi side of their business, is proof enough.
In the end, it's all about the music. Enjoy! :music:
Lee.
Hi folks, found this thread by searching Google for 3020 retorations. I am a relatively new AudioKarma member and after reading a lot of the positive comments about LeeSonics, I am very impressed with Lee's work on the NAD amps and preamps. I have a 3020 that I inherited with a few noise problems. I have had it repaired to some degree at a local vintage stereo repair shop but it still has some minor issues so I would like to go ahead and just have it restored. I guess I would like to ask if LeeSonics (Lee) is still currently taking on NAD 3020 restoration projects and if so, how do I get my 3020 into the queue ?
Thanks
Dean
PM Lee and see if he has the time for it. Just click on hisusername in the post above yours and you'll get a dropdown menu allowing you to PM him.
PM already sent to Dchristie. I'm still doing this work, there were five NAD amps in my dining room last week.
Lee.
leesonic just restored my recently acquired NAD 3020. Now I get what all the hype is about with this amp, as well as with Lee's restoration skills. He even took the time to completely clean up the unit, both inside and out. Outstanding!
Here it is driving modded BS22s and a Polk PSW10 sub. Love me some Julie London on this setup.
attachment.php
attachment.php
Hello everybody my name is Jim Peterson. I am also an original owner of a NAD 3020. It overheated a while back and I would love to get it fixed. I tried to look up Leesonic on the google and couldn't find any contact information. I am hoping that he will this post or someone can give me his number.
425 249-8756
Hey Jim...
Welcome to AK :) You should send a message to Leesonic by clicking on his avatar then clicking on "Start a conversation".
IMO you really don't want your name and phone number posted in open chat where the internet trolling bots will snatch it up, and who knows who will end up with it. You can edit your post to remove that info.
Hey Jim...
http://audiokarma.org/forums/index.php?members/leesonic.48181/
Here is a link to Lee's profile. If you send him a message he'll respond. Great guy to work with!
