If you're not familiar with this speaker model, you're not alone...because neither was I. These are in fact M&K SV-200B's, built in the mid 1980's. For those of you who need to catch up, here's some background info in a thread which was started when I first found these guys --> https://www.audiokarma.org/forums/showthread.php?t=519388
> Part 1 - plate amp rebuild <
As you can see from the previous thread, the electrolytic caps on the amps were in bad shape. Two fully corroded through legs on different caps, prevented the one amp from working properly. Using the Volkswoofers was a no go.
So, this became a project and put on the back burner, since I had no extra funds for these at the time.
However, I did apply some Watco Rejuvenating Oil to the cabinets at that time, which made them look like new again. I also re-glued the foam padding down above the woofers, which was peeling off. Then for Christmas 2013, I had the 12" woofers re-foamed as a gift. Slowly but surely, this project was going to be finished. :yes:
Fast forward to last week, when I FINALLY ordered all new parts to rebuild the plate amps and power supplies of the Volkswoofer 2B portion of the speakers. The parts list included the following:
- Elna Silmic II electrolytic caps; throughout amp
- Nichicon Gold Tune (KG) Type-II electrolytic power supply caps; bumped up from 7200uF to 8200uF
- Vishay ceramic safety power supply caps
- Vishay zener diodes
- Vishay ultrafast rectifiers; upgraded from 1N4002 to UF4002
- Vishay/Dale 1% and 2% precision resistors; in place of all 5% resistors
- Texas Instruments op-amps; for the hell of it
- CTS volume pots
- Bournes trimmer pots; for crossover adjustment
- 16 gauge polarized AC power cables; non grounding
- gold plated female RCA inputs
- new fuses inside and out
- Cardas Quad Eutectic solder
Now, down to business. With the help from Ken Kreisel himself, who offered up the schematics, manuals and any other questions that might need answering (Thanks Ken!), I warmed up the Pace soldering station and prepared for battle.
First, I removed the plate amps and power supplies from each speaker, then disassembled one. On the first amp, I removed all the old parts that were to be replaced by new, leaving one amp together as a visual aid. Each board was scrubbed with a dry old toothbrush and sprayed off with DeoxIT D5 before the new parts were installed, along with all eletronic connections. I had a local tech and AK member DanO55 test the STK power amp modules for me, to make sure they were good, which they were (Thanks Dan!).
Next up was to replace the the RCA inputs, gain pots and power cables. (and clean the dust of those plates!)
So, this became a project and put on the back burner, since I had no extra funds for these at the time.However, I did apply some Watco Rejuvenating Oil to the cabinets at that time, which made them look like new again. I also re-glued the foam padding down above the woofers, which was peeling off. Then for Christmas 2013, I had the 12" woofers re-foamed as a gift. Slowly but surely, this project was going to be finished. :yes:
- CTS volume pots
