It has been a while since I posted a DIY thread, so I thought I would chronical my latest AK commission: a nice little Toshiba Mini Combo -> SY-C15 Preamp/SC-M15 Power Amp.
These units turned out to perform better than original factory specifications, and are quite impressive little units.
I never do a recap on a unit that is not already performing fully, so, 1st any necessary repairs must be done. Then, the unit is tested lightly, as a baseline to compare against, after recapping. Then, the recap is performed, and extensive final performance and functional testing is performed.
Power amp repairs:
1. The power amp protection circuit cycled on and off, which I found to be some old, cold solder joints in the bias circuitry of the right output channel. A key to this repair was the fact that, the problem was vibration sensitive (it would come and go when the main circuit board was lightly tapped. Reducing the tap strength help to localize the area of the circuit board that was affected. Inspection with a jeweler's loupe in the area showed a few suspect solder joints, and probing on them showed which ones were the problem. Retouching the solder joints solved the problem.
2. The speaker output relays were then found to be just a bit marked, due to arcing. LIGHT burnishing of the relay contacts cleaned them up nicely.
Preamp repairs:
1. Everything worked, except the "Standby" function. The outputs would reduce in volume to various degress, as the "Standby" switch was cycled, but the signals would not fully mute. When the "Standby" switch is engaged, an internal relay shorts the output terminals to ground (after a decoupling resister, of course). The contacts on this relay were found to need a light burnishing. That got it.
I have attached a couple of pics of this little set.
Rich P
Power amp repairs:
Preamp repairs:
Rich P
