ev13wt
We shall start off simple. The aim of this thread is to see if we can hear differences between the original CD quality and various levels of MP3 encoding bitrates. This thread is meant to be fun, not anything scientific or here to prove or disprove anything.
What you need: Foobar player, latest version and the plugin ABX comparator. Both are free.
First install Foobar. Then install the comparator.
Links:
Foobar: http://www.foobar2000.org/download
ABX Comparator Plugin: http://www.foobar2000.org/components/view/foo_abx
Then, download the test samples here: ZIP: http://s000.tinyupload.com/index.php?file_id=01672209526889323564
Original WAV: http://www.filedropper.com/vivaldisample
LAME MP3 103Kbit (low quality): http://www.filedropper.com/vivaldisamplemp3lamelevl6105kbit
LAME MP3 175kbps: (mid quality) http://www.filedropper.com/vivaldisamplemp3lamelevl3175kbit
LAME MP3 320kbit (highest quality): http://www.filedropper.com/vivaldisamplemp3lamelevl1320 CBR kbps
FLAC lvl1: http://www.filedropper.com/vivaldisampleflaclvl1
Update edit: More samples
Herbie Hancock River Track 2 Edith and the Kingpin SAMPLES for AK
http://s000.tinyupload.com/index.php?file_id=97712256719191631194
From user "botrytis" Here is some files to listen to - John Williams 'Bourree all Polacca' from the Baroque Album - classical guitar. This will show the differences quite well.. http://www.filedropper.com/johnwilliams
Load the Original WAV and the low quality MP3 into Foobar, select both, right click and then click "utilities" and "ABX tracks"
Settings as is, make sure you have level gain edit: "use replay gain/simple gain track" checked and DSP unchecked. Do the test with at least 10 repetitions and post the results in this thread.
ROUND 1 (EASY) // WAV vs. 105 kbps (Low quality)
foo_abx 2.0 report
foobar2000 v1.3.7
2015-02-02 21:57:15
File A: Vivaldi Sample.wav
SHA1: 8740e27fac3bbda22ecd15c57d7b9aa2b608174b
Gain adjustment: +5.10 dB
File B: Vivaldi Sample MP3 LAME levl6 105kbit.mp3
SHA1: ea10304ff649fb7940643657bc416949498da071
Gain adjustment: +5.09 dB
Output:
ASIO : ASUS Xonar ASIO driver
Crossfading: NO
21:57:15 : Test started.
21:57:25 : 01/01
21:57:34 : 02/02
21:57:42 : 03/03
21:57:51 : 04/04
21:58:00 : 05/05
21:58:08 : 06/06
21:58:15 : 07/07
21:58:24 : 08/08
21:58:31 : 09/09
21:58:39 : 10/10
21:58:39 : Test finished.
Total: 10/10
Probability that you were guessing: 0.1%
-- signature --
85b712b4bd5338c26174f3dc3d024862cb1a6381
Since the background noise is quite high here right now, I will ABX the next rounds later.
Links:
foo_abx 2.0 report
foobar2000 v1.3.7
2015-02-02 21:57:15
Output:
Crossfading: NO
21:57:25 : 01/01
21:57:34 : 02/02
21:57:42 : 03/03
21:57:51 : 04/04
21:58:00 : 05/05
21:58:08 : 06/06
21:58:15 : 07/07
21:58:24 : 08/08
21:58:31 : 09/09
21:58:39 : 10/10
Total: 10/10
-- signature --
