ScottHinson
So, what started out as a quick little writeup about crossovers...turned into a bit more...about 60 pages more.
The DIYRM-A is a Do-It-Yourself Reference Monitor....much along the lines of an LS3/5a. Can be used a bit more broadly and works better with modern music.
The writeup can be found at:
https://goo.gl/XboqRW
The file size is about 20X larger than the AK forum will host directly.
The document covers:
They are excellent for a variety of applications from near-field monitoring, two channel stereo where space is a concern and surround sound applications, again where space prevents the use of larger designs.
I hope you enjoy.
Scott "SpeakerScott" Hinson
Introduction
Design Goals
Driver Selection
Enclosure Design and Construction
Design Measurements
Crossover Design
Listening Notes
Crossover Power Handling Testing
Conclusion
Design Goals
Driver Selection
Design Measurements
Crossover Design
Listening Notes
Conclusion
I hope you enjoy.
