ToTo Man
NEVER ENOUGH TOTO!
In my BEDROOM, i have little more than $300 invested, and i've got the speakers in the only place they can be (against the front wall), and my listening position is on my bed with my head about 1ft-2ft off the rear wall. Recipe for disaster you may think, but its quite the opposite. With a little EQ I can get a PERFECTLY flat frequency response from 40hz to 16khz (or so my spectrum analyser tells me) and it sounds absolutely wonderful. No echoes or resonances, just smooth sound that I guess is what you'd get in a properly built studio.
Anyway, onto my MAIN ROOM, the room where I do 90% of my listening, the room which is a NIGHTMARE to get even sound in. I have a total of $3500 invested (between vintage and 5.1), I've spent a long time on positioning, but I'm still not happy with the sound.
The room is pretty live. Bare windows, parque flooring (with a rug-carpet covering 67% of the floor), no damping materials on the walls. The room is rectangular with 3 straight walls and a bay window. The dimensions of the room (excluding the bay window area) are: 18.5ft long x 15.5ft wide. My listening position on my sofa is 6ft from the rear wall and exactly in the center of the room in terms of width. The bay window is 4ft long at its deepest point. The backs of the speakers are 1ft off the wall (but of course the bay window extends this).
With my floorstanding speakers (Wharfedale Valdus 500) I am experiencing a peak at around 100hz which is very wallowy/echoey. Before I moved the speakers to their current positions, I had them more in the corners of the room, about 3 to 4 inches off the rear wall and toed in to my listening position. There was no 100hz peak, but there was a huge peak at 60hz. Since moving them the 60hz peak has disappeared but a 100hz peak has taken its place. Please take some time to look at the attached photos. Any advice on how to eliminate the echoey peak? I think the problem may be the bay window area, but it could also be my speakers (I don't think they have any damping material inside them).
Also, I have recently installed subwoofers (the big KEF cabinets next to the Wharfedales) to fill in the 30hz to 50hz gap missing from my system, but placing them has been a huge PITA. I ended up giving in and just placing them on the same plane as the Wharfedales. In my so-called 'sweet spot' on the sofa, I can hardly hear my subs, but move my head forward 2 feet and BANG, the subs come to life. When I walk round the room I notice similar effects
. I know that waves can add and cancel, but is it really so noticeable? Apart from moving my sofa forward 2 feet, any ideas on how to improve the sweet-spot?
FWIW - The Wharfedales are run full range, and the subs are crossed over ar 50hz with a 12db/oct slope (-3db @ 50hz), but this wasn't enough of a roll off for me so I've used my 33band EQ to cut all frequencies above 50hz by a further 12db.
. I know that waves can add and cancel, but is it really so noticeable? Apart from moving my sofa forward 2 feet, any ideas on how to improve the sweet-spot?FWIW - The Wharfedales are run full range, and the subs are crossed over ar 50hz with a 12db/oct slope (-3db @ 50hz), but this wasn't enough of a roll off for me so I've used my 33band EQ to cut all frequencies above 50hz by a further 12db.
, but to do this I'd need to move the whole room around! :nono:
