PR Audio
Well, After approx. 1 yr. with the drivers and parts laying around I finally decided to start my Hybrid Open Baffle Bookshelves, since looks, location, and size are important, compromises had to be made. In order to keep them as compact as possible a HiVi M5N 5" Wooferin a Ported Box will be used, along with a 4" Mark Audio CHR70.3 Full Range Driver in a folded Open Baffle configuration.
Ported Box is 7-1/2" Wide x 16" Tall (10" is the box baffle and 6" the OB, all one piece)x 9-1/4" Deep with a 1" Dia. x 2-1/16" Long Vent. This box shall give an f3 of 58Hz and an fb of 54Hz. Total capacity is 0.25 cu.ft. (7.07 Lts). I tried to dimension the box as per the Golden Ratio, but because of aesthetics a compromise was made.
OB is folded with a height of 6", and a total length of 10-1/2". According to simulation on the Edge software this only gives me a 2.5dB rise starting at around 456Hz peaking at around 1,200Hz, and dropping back to same level as it started at around 3KHz, it is not more than 2.5dB and the rise and fall are fairly "soft" like a table top curve, not a quick peak, so not much worried about it, but I'm sure that others here will find flaws and comment.
For the enclosures I'm using 1/2" MDF that will be veneered. I will seal the seams of the enclosures from the inside with some kind of silicone or caulk.
Prior to building a passive x-over for them, most probably a 2nd order, but open to your suggestions as not an expert (self-taught on this matter), I will use a Behringer 2-3 Way Active X-Over to dial the frequencies. My intention is to cross after 460Hz, this will be my starting point, but obviously I will experiment going lower and/or higher.
Bi-Amplification and sources will be sort of a mixed bag of a Conrad Johnson KT90's 75WPC Power Amp, DIY 80WPC @ 8 Ohms Class D Solid State Amp (I have a thread with the build somewhere in AK), McIntosh MX-113 Pre-Amp, Jolida JD603 CPD, PC with Audioquest Dragonfly DAC, and Rega P2 TT slightly modified with a stock Grado Gold Ctdge.
The worst that will happen is that I have to trash them, and move on to another project using those drivers, from a $35.00 4'x8' MDF panel I have made a pair of TABAQ's, a 2 pairs of uFonken, the Hybrids I'm building, and still have wood for another set of hybrids or bookshelves for a 5-1/4" Two Way or maybe TABAQ's or 2 more pairs of uFonken.
Any suggestions are welcome, especially when it comes to x-over design and components. I think I will build, use, then start the veneering process.
