cheap easy DIY speaker riser/stand for my wharfedale 70's
easycraig
2 pieces of 2x2's finished for about $10. plus 1 pack of riser/sliders ($3.) plus screws and a 1 x 2 I had laying around. We recently bought a package of felt feet stickers ( don't know the exact name ) from costco for about $10... I think there are 100+ pieces(maybe 200) in there of various sizes.... (great deal).
-Anyways... put these together tonight... will stain them tomorrow when I find our stain box..... ( more pictures then )..... less than $20 bucks done. For those that care, my listening space is in our garage, and the floor is not level... so I put the risers on the front end of the stands so I could easily make the speakers level... -probably somewhat important because on one of the speakers my turntable sits. ec
Nicely done. Seems a lot of Work for a 2 " rise tho.
Is that enough elevation to raise your Driver's centreline axis to a seated listeners' ear height? (~38" )
good looking stands.
I would recommend that since you are using the garage for your listening space, a wall shelf for the turntable would be a good thing to do. Isolate it from the direct speaker vibrations would help the sound quality.
Shelly_D
all ^ valid points..... appreciate the suggestions.... - but can't do them because one speaker sits under a credenza (so the stands in the front are just under 4 inches) -would mount the turntable on the wall, but i am doing my best to keep the artwork visable, and if i end up getting any noise with the turntable on the speaker i figured i could put it on the credenza if necessary. Pictures later today after the stain has dried and i get everything back together. ec
here we go.... i need to get an extension cable for the rca phono jacks so they don't show behind the chair, very pleased though. Sound stage is even bigger now! -love these speakers with the tubes...... -no phono issues so far with the tt on the speaker!
adding length to the phono rca cables also adds capacitance. Having the right capacitive load on the phono cartridge is critical to getting the best performance and some cartridges are more sensitive to that then others. Would there be a way to bring the turntable and preamp closer to each other? The length of cables between the preamp and power amp will be much less critical to the results and you can add length with little or no decrease in sound quality. I guess I asking if you can do a rearrangement of the units on the right to bring the turntable over that side and move that Stereo 70 over to the left. It might take another build to make a level platform from the desktop out over the speaker to do it.
Shelly_D
those stands lend themselves to alot of expansion for diff use in height and width
for equipment shelving.
Just what I been lookin for.
For my friend's big Altecs I built something for the same purpose.
But it was just a simple 4" high frame painted black to gain some elevation.
He said they originally came with a similar frame.
