This build thread is for 'Take Two' of the DG-SE1 amp that Mr. Gillespie has so graciously shared with us. My first build is documented in a prior thread, but this one is going to show a bit more of the 'from' and 'to' aspects of what I'm doing....for anyone who's interested.
The project starts with one of two choices; either A) build the thing from 'scratch', or B) find a suitable 'donor'. Dave's original intents were to 'upgrade' the stock Magnavox 8604 to something of a respectable nature. However, in so doing, he actually created a 'project' amp that is easily built, not too costly, and performs amazingly well. But...that's all documented elsewhere. This project goes with selection 'B'....use of a 'donor amp'. In this case I chose a small SE-EL84 amp that I'd resurrected some time back. In the pics posted you'll note that it's NOT a 'Maggie' amp, but that it IS similar. It uses the same 4 tubes though I believe this was originally wired for a 12A'X' vs the 6EU7. I put the 'X' in parentheses as it don't know if it actually was an 'X', a 'U', a 'T', or what. But, in looking at the filament wiring, it's pretty obvious to me that it came that way...... I don't think I 'modified' it as I've done with some of the Maggie amps.
Anyway..... this post will end with the 'Donor' amp being photographed and shown in the pics below. BTW, I started this at about 9:30 am today, and it's now pushing 1:00. This, and the next post, are the progress made in about 3 hours of effort.
I also want to note 'why' I chose this amp as a donor: I spent some time yesterday doing some 'listening' tests between 4 of these little 'flea' amps. In looking at this unit, it clearly 'looks' as if it should be a great performer. The size of the OTs made me hopeful that it would FAR outshine the performance of the little Maggie. However....it actually sounded pretty lame. In looking underneath, you'll note that it's significantly different in design from the Maggie amp. And, the caps are OLD and probably shot. So, this amp made a great candidate for an overhaul. And, I'll now be able to clearly distinguish the change in performance as I have both my original DG-SE1 AND 2 OE 'Maggie' amps to compare this to. Should be interesting!
WC
WC
