Well, the beat goes on! This build was a 'proto-type' for a 5 volt rectifier version. I know DerekVa used a 5V rectifier in his..... and after giving the matter some further consideration, I decided that prior to my 'final' build, I need to do a mule version myself. So, this was that.
In all honesty, I 'thought' I was doing pretty good with this amp. Started with the 5AR4 rectifier.....and after finishing the build in relatively short order, I got the voltages all within Dave's spec....... and hooked up the test speakers. Sounded good on those....so went to the Cornwalls. At that point I started hearing some hum....and actually lost a channel. Long story short, the loss of channel was in the driver tube socket...... just dirty. BUT.... this noise problem revealed that I also had no 'separation' between channels. Amp was acting like dual-channel 'mono' amp...where input from either channel drove both channels equally. Quick Shout-Out to Gadget and Dave for finding my failure to connect my speaker 'negative' connections to chassis ground. And, 'rookie' error on my part. Fortunately, quick and easy fix.
After running amp for several hours I noted that my PT was getting REALLY hot! Unlike Dave's 'original' DG-SE1, in my builds I've been using a 4-stage power supply filter system. This in order to 'adjust' the B+ voltage between stage 1 and 2....with stage 1 being a cap off the rectifier and the choke. Choke feeding second stage cap. Then, an 'adjustable' bridge resistor between stage 2 and 3...which allows me to set Stage 3 at the specified 265 volts. Then the 820 resistor between stages 3 and 4. Anyway, I had a 500 ohm resistor in my 'adjustment' stage when using the 5AR4. I tried a 5Y3 and was able to drop the resistor to 130 ohms.....or 370 LESS ohms of resistance in the PS. I'm not sure the filament draw of the 5Y3 has any advantage over the 5AR4....but I 'might' have reduced the heat in the PT by a smidgeon. It's still hot....too hot for my liking....but after several hours of straight running......it's still alive. So....for now, I'm living with it.
Amp is built WITH the associated Bias Adjust Pots....and REALLY sounds good! This may be psychological.....but I think getting this amp at EVERY detail of the specs provided DOES improve it's performance. However, my very first build still impresses me...and I've yet to add the bias pots to it.
Anyway....my 'Final' build of this amp will be with the Transcendar 7W OT, and with a Hammond 270EX PT. The Hammond PT is rated at 144ma of DC current capability...with a 3A rectifier filament section, and a 4A filament section for the output and driver tubes. Maybe 'overkill'....but this one will NOT overheat!! Also using the new Dynakitparts C-354 choke, with a bit more inductance (1.75 vs 1.5 of the Hammond) and being 'shielded'...which is something I couldn't find on any of the Hammond units. But, more on that build when it begins. Parts are all ordered....2 to 3 weeks to get the OTs from Transcendar. Thread will begin then. For now, regarding build 4, I'm going to quote DerekVa here....and say it's time to stick a fork in it and call it 'done'........
Thanks for looking! BTW, note the neat label atop the chassis for the Bias adj level!! label maker: Flea Mkt find - $1 WC
