henry.bowman
I'm not interested in whether you believe that cables make a difference. I've already decided that for myself, and found my perfect cable a couple years back.
Now that I have 501's though, I am not sure I have enough wire gauge to deliver all the power to my speakers.
If one has 84-85dB speakers with 501's (which can allegedly pass 1000 watts into 4 ohms), what gauge wire is the minimum to get all that power into the speakers?
Right now I have Audience's Au24 speaker cable, and I don't know the exact gauge, but I know the entire cable is 4mm in diameter total, including the outer covering.
Would another run of this increase the gauge enough to do the job? Or is it a non-issue?
Thanks!
Thanks!
