skibjr
I’m a sucker for a hard luck case. I picked up a beat-up HK Citation 16 this past April thinking I could restore it and use it in my own personal system. In retrospect, I don’t know what I was thinking. Perhaps, “It couldn’t be that bad… could it?” Well, it was. Worse, in fact. Rusty, rained on, bent, dirty, chipped – generally beat to crap. And that was just cosmetics. After getting it on the bench, I discovered 60 VDC on the left speaker output, and no signal present on the right. Turns out it had evaporated traces, a few dead caps and several open resistors on the driver boards, two bad emitter resistors, burned out display LEDs, dead neon pilots, and apparently, an arcing problem with one of the TO-3 driver transistors, where under high current conditions the transistor case had burned a hole through the mica insulator and had arced to the grounded heat sink! (see arc-welded tranny, below)
Okay, fixed all that, hooked up an input source and gradually brought up the volume. Sounded great – that is, until I hit about 5 watts output at which point the amp started distorting horribly, with sharp, staccato transients – it sounded exactly like a crummy woofer sounds when you bottom out the voice coil. I put a scope on the left output and gradually brought up a 200 Hz sine wave with no load – perfect. As soon as I connected a load and brought the input signal up a little bit, however, I started getting a low frequency parasitic oscillation on the upper part of the sine wave (see photo). I connected the scope and load to the right output and got exactly the same oscillation, just in reverse phase, spiking up on the lower part of the waveform.
What the hell? The Citation 16 is a true dual mono-design – each channel is completely independent of the other. The output signals for both channels travel through a relay board, but no way that could cause equal but opposite phase oscillation under load in both channels. Guess I’m not as smart as I thought I was, because it took me almost a week to finally figure out what was happening. Seems pretty obvious to me now, but it gave me fits for a while. Anyone here care to guess what the final bitch-kitty turned out to be?? :scratch2:
I thought it had to be the rectifiers, but they all checked good.
Oh well - she'll probably never be much to look at, but I can't wait to hear her purr once I get that brand new four-barrel under her hood!! :thmbsp:
