ToTo,
I'll claim ignorance here but does a place like Parts Express here in the states ship your direction, at least at a reasonable rate? That's where I've always gotten my Caig products anyhow. Use the product when you get it, very happy you haven't had problems so far!
Guess I kinda knew this would be a bit of a can of worms but this is pretty common knowledge (IMO) that most of the deoxit type products that really work can be hard on the carbon tracks in pots. It has been mentioned here in the threads before but seems to get lost somehow in the vapor. What's also been lost a little I guess is why we use deoxit in the first place, to remove oxide from the contact surface. Metal contacts, like in switches rotary or otherwise are metal to metal and obviously benefit from having the oxidation removed. In a pot, ie our old carbon trace pots, carbon does not oxidize. The only part that "could" is the wiper. I guess there's the rare case of say a hostile enviornment where a wiper could corrode quickly enough to cause a problem but in my experience the wiper doesn't usually corrode that badly until either the carbon track is worn out from use or the pot has been "jammed" causing the wiper to be misaligned. The lube works to quiet the pot, not really as a deoxicant. Think of a pot working on a miniature scale like the carbon brushes you see in an electric motor like a drill motor. I realize the scale and interruptions on the commutator is different so don't drag me over the coals.... comparison is for visual effect. The noise we get from old or worn pots is the wiper to carbon rubbing, a microscopic making breaking contact so to speak.
Brudha
You asked so I'll sum up then shut up... the only time deoxit would help in a pot is if there were to be old lube interferring. The MCL or faderlube does the same thing getting the dried or old lubs outta the way and leaves a fresh coat, which is essential. All deoxit will do is get the old lube off and leave a dry pot. Why take the chance it'll also lift the track on an unobtainium part? It's the old 99 outta 100 times you'll get away with it but that one time it really matters ol Mr. Murphy.....
Ron
