CDFixer
Number 1 USC Trojan Fan
I have been wanting to do this for sometime but just never got around to it. We all know how hot this little power supply runs and that it is one of the failure points, I did a little experimenting and came up with the following modification.
Remove the 2 5W 270 ohm resistors.
Install a 200 ohm 25 Watt resistor in its place, use sleeving on the leads and place the resistor against the chassis.
This does two things, I moves the resistors away from the heat sink for the regulator transistor and by increasing the resistance by 65 ohms it reduces the voltage at the regulator from 34 to 21 volts the regulator does not have to work as hard as it did before and it doesn't get near as hot.
Here are the temps that I measured before and after the mod.
Starting temp before mod Heat sink 85F/29.4C Resistor Same
Temp 5 minutes after pwr Heat sink 153F/67.2C Resistor 164F/73.3C
Temp 10 Minutes after pwr Heat sink 166F/74.4C Resistor 168F/75.5C
Starting Temps After Mod Heat sink 91F/32.7C Resistor 81F/27.2C
Temp 5 minutes after pwr Heat sink 112F/44.4C Resistor 116F/46.6C
Temp 10 minutes after pwr heat sink 118F/47.7 Resistor 133F/56.1C
Temp 1 Hour after pwr up Heat sink 124F/51.1C Resistor 133F/56.1C
There is a radical difference in the temps before and after.
The regulator is adjustable so it will need to be adjusted to 12.5 volts after the mod.
I am fashioning a clamp for the resistor that will help disipate more heat to the chassis.
