Polk R300 tower $99.98 a pair @ Fry's
sleddogman
Unlike Circuit City and the Sony scam, these are actually in stock... :thmbsp:
http://www.outpost.com/entry?site=op:mfe031406&sku=4965501
Sold at $49.99 each - limit 2
(when purchased between 01/12/2007 and 01/16/2007)
POLK AUDIO R300
Floorstanding Tower, 6.5" Mid/Bass Drivers
SOLD INDIVIDUALLY
LIMIT 2 PER CUSTOMER
Polk:
FRYS.com #: 4965501
The R300 Series Loudspeakers are perfect for building starter systems, or for small room or multi-room applications. With the addition of a PSW Series powered subwoofer, you can assemble an impressive home theater system on a budget.
Limit 2 per Household.
With a minimum of fuss and expense, R Series speakers ably reproduce accurate sound with impressive volume, in attractive, solidly built cabinets finished in basic black.
Features:
* Acoustically inert MDF cabinet, finished in black.
* Slim tower design conserves floor space, occupies less than one square foot.
* Polk Audio's exclusive Dynamic Balance polymer composite driver for smooth wide-range response with low distortion.
* 3/4" silk dome tweeter with neodymium magnet for clear, detailed highs.
* Rear-firing bass port for high efficiency and powerful bass response.
* Acoustically inert stamped driver baskets and butyl rubber surrounds for high performance durability.
* Anti-diffraction grills minimize grill diffraction for spacious, three-dimensional imaging.
* Magnetically shielded for safe placement near video sources.
* 5-way binding post inputs for the most secure connections and the most versatile wiring applications
* Timbre-matched to fit into any Polk Audio home theater or multi-channel music system for a more realistic, more seamless surround sound environment. |
Driver Complement
o Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
o Dynamic Balance mineral filled polymer composite cone driver, shielded
o Tweeter 1 - 3/4" Diameter (1.91cm)
o Dynamic Balance silk/polymer composite dome, shielded
Electrical
o Overall Frequency Response 45Hz - 24kHz
o Lower -3dB Limit 55Hz
o Upper -3dB Limit 20kHZ
o Nominal Impedance 8 ohms
o Recommended Amplifier Power 20 -150 w/channel
o Efficiency 89 dB
o Inputs 5-way binding posts
o Cabinet Size 33" H x 7-3/4" W x 8-3/8" D
o (83.82cm H x 19.68cm W x 21.27cm D)
o Enclosure Type Vented
POLK AUDIO R300
SOLD INDIVIDUALLY
Polk:
FRYS.com #: 4965501
Features:
Driver Complement
Electrical
o Efficiency 89 dB
I wonder if they're any good?
It's certianly hard to argue with the price, but the drivers are cheap stuff - the woofers are nothing special, and the tweeters are likely in the same range as the $5 Dayton neo tweeters or $9 hi-vi K1's. (For my $100, I'd rather go with the ZaphAudio silver flute/vifa combos.)
That said, it's the crossover that makes the speaker, and you can do a lot with a little if you're good at it.
These are the same thing as the R30's they've been selling for years! :thumbsdn:
The R50's are the ones to get if you can find them. :thmbsp:
Otherwise, the Insignias or Radiience still reign supreme.........:yes:
